Einleitung
Are you wondering why your Nespresso coffee is tasting off and doesn’t have that sufficient taste? Use this guide to learn how to descale your Nespresso VertuoPlus machine in an easy few steps.
Descaling your coffee machine is ultimately cleaning and stripping any excess dirt that has built up on the machine’s surface which could potentially cause your coffee machine to stop functioning properly and result in bad-tasting coffee.
Before using this guide, make sure you have the Nespresso descaling kit. Any other type of cleaning solution used in the machine could potentially break the machine.
Was du brauchst
Turn the machine on by pressing the button with a coffee mug logo.
Lift the lever upwards to remove any used capsules from the machine.
Empty the capsule container that is located at the back of the machine.
Fill the water tank with one unit of the Nespresso descaling liquid and add three cups of water to the solution.
To access the descaling mode on the machine, push both the button and lever down for three seconds.
Empty the descaling liquid from the water tank.
Rinse and clean the tank thoroughly.
To exit descaling mode, press both the button and lever at the same time for three seconds.
A green light will show, indicating the descaling has been completed successfully.
39 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
When I hit the button to begin the descaling process, the orange light flashes for a few seconds then I get a red ring and the machine stops
I usually require six envelopes to descale (six times). We have very hard water where we live. Keep repeating process. Once machine has descaled enough, it will go back to green. Persistence wins.
perchè pur funzionante si accende la spia circolare di colore per metà rossa e metà verde?
Devi fare la decalcificazione ti da ancora la possibilità di usarla ma per un breve periodo
Perché dopo aver fatto la decalcificazione compare ancora la spia metà rossa e metà verde?
