Einleitung
This is a prerequisite guide! This guide is part of another procedure and is not meant to be used alone.
Use this guide to disconnect the battery in the Xiaomi Redmi Note 8.
Was du brauchst
Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner of your phone.
Slide the opening pick along the left edge of your phone to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick underneath the top left corner of your phone.
Slide the opening pick along the top edge to slice the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick underneath the top right corner.
Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
Carefully fold the rear glass to the right side of the phone assembly like you'd open the back cover of a book.
Use a spudger to disconnect the fingerprint reader by prying the connector straight up from its socket.
Remove the rear glass assembly.
Use screwdriver to remove the eleven screws securing the motherboard cover:
Ten 3.9 mm-long Phillips screws
One 3.4 mm-long Phillips screw
Insert the tip of an opening pick underneath the bottom left edge of the motherboard cover.
Slide the opening pick along the left edge of the motherboard cover to unhinge the plastic clips and pry it up.
Insert the tip of an opening pick underneath the bottom right edge of the motherboard cover.
Slide the opening pick along the right edge of the motherboard cover to unhinge the plastic clips and pry it up.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
