Zum Hauptinhalt wechseln
How to Enlarge a Skirt Waistband
Was du brauchst
  1. How to Enlarge a Skirt Waistband, How to Enlarge a Skirt Waistband: Schritt 1, Bild 1 von 1
    • Measure the waist band with a ruler or measuring tape.
    • Measure your waist.
    • Subtract the two measurements to determine how many inches you want to add on.
  2. How to Enlarge a Skirt Waistband: Schritt 2, Bild 1 von 3 How to Enlarge a Skirt Waistband: Schritt 2, Bild 2 von 3 How to Enlarge a Skirt Waistband: Schritt 2, Bild 3 von 3
    • Measure roughly 2 inches below the waistband.
    • Mark a vertical line with a tailor's chalk, a white pencil, or pins.
    • Cut down to the end of the line.
  3. How to Enlarge a Skirt Waistband: Schritt 3, Bild 1 von 3 How to Enlarge a Skirt Waistband: Schritt 3, Bild 2 von 3 How to Enlarge a Skirt Waistband: Schritt 3, Bild 3 von 3
    • Measure and mark the elastic to twice the length you want to add on.
    • Cut the elastic strip.
    • Then, cut that same strip at the halfway mark.
  4. How to Enlarge a Skirt Waistband: Schritt 4, Bild 1 von 3 How to Enlarge a Skirt Waistband: Schritt 4, Bild 2 von 3 How to Enlarge a Skirt Waistband: Schritt 4, Bild 3 von 3
    • Overlap your elastic strips from step 3.
    • Depending on how many inches you are adding on, you may need to cut several strips.
    • Sew the strips together
    • Be cautious of where you place your fingers when dealing with sharp objects.
  5. How to Enlarge a Skirt Waistband: Schritt 5, Bild 1 von 2 How to Enlarge a Skirt Waistband: Schritt 5, Bild 2 von 2
    • Fold the elastic in half.
    • Cut at about a 60 degree angle (creating a triangle).
  6. How to Enlarge a Skirt Waistband: Schritt 6, Bild 1 von 1
    • Turn the skirt inside out.
    • Sew the elastic triangle into the opening you cut in Step 2.
    • Try your new skirt on for size.
Ziellinie
Nisha Sahota
133 Reputation
1 Anleitung geschrieben
UC Davis, Team 4-7, Vidal-Chiesa Fall 2024 Mitglied von UC Davis, Team 4-7, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G7
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 44
