Zum Hauptinhalt wechseln
How to Extend A Necklace Chain
Was du brauchst
  1. How to Extend A Necklace Chain, Necklace Chain: Schritt 1, Bild 1 von 1
    • Use nail clippers to cut the links off of your extension chain until it is your desired length.
  2. How to Extend A Necklace Chain: Schritt 2, Bild 1 von 1
    • Remove the links you just cut from the end of the extension chain so you have a chain of your desired length.
  3. How to Extend A Necklace Chain: Schritt 3, Bild 1 von 2 How to Extend A Necklace Chain: Schritt 3, Bild 2 von 2
    • Use the pliers/tweezers to grip the ends of the last link you removed and pull it open to widen the gap.
  4. How to Extend A Necklace Chain: Schritt 4, Bild 1 von 1
    • Thread the link you just opened wider through your original necklace chain.
  5. How to Extend A Necklace Chain: Schritt 5, Bild 1 von 1
    • With the link attached to the original necklace chain, attach the extension chain to the same link.
  6. How to Extend A Necklace Chain: Schritt 6, Bild 1 von 1
    • Use the pliers/tweezers to pinch the link shut around both chains.
  7. How to Extend A Necklace Chain: Schritt 7, Bild 1 von 1
    • Using the original latch, clip the latch to the extension chain. Your final product should look like a seamless chain!
Abschluss
This necklace is now ready to wear, and the chain can be extended with this method many times!
MaryJane M.
145 Reputation
1 Anleitung geschrieben
UC Davis, Team 4-5, Andersen Winter 2023 Mitglied von UC Davis, Team 4-5, Andersen Winter 2023
UCD-ANDERSEN-W23S4G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 208
