Einleitung
Use this guide to repair the power supply with a Phillips head screwdriver, a wrench, and pliers. These tools will help secure the screw holding the wire.
  1. First, to remove the plastic bracket, turn toaster oven on its side.
    • First, to remove the plastic bracket, turn toaster oven on its side.
  2. Use Phillips head screwdriver and wrench to remove screw and nut securing the plastic bracket.
    • Use Phillips head screwdriver and wrench to remove screw and nut securing the plastic bracket.
    • Use Phillips head screwdriver and pliers to remove screw and nut securing transformer.
    • If the wire gets pulled out of the transformer, reinsert it.
    • Use a small flathead screwdriver to secure the screw that holds the wire in place.
Abschluss
Tony Wang
Mitglied seit 05.10.2012
64 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 6-35, Regan Fall 2012 Mitglied von Cal Poly, Team 6-35, Regan Fall 2012
CPSU-REGAN-F12S6G35
4 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 703
