Einleitung
Use this guide to bevel a sharp, potentially hazardous, edge on your garage door.
Many garage doors have metal railings that could contain sharp edges and such dangers might pose a threat and cause the garage door to be replaced. Here, we provide instructions on how to eliminate a sharp edge on a garage door to reduce waste and cost associated with replacing an entire garage door.
Be sure to practice caution when working with the sharp edge.
Was du brauchst
Disconnect the garage door from the power supply.
Spray the cleaning solution on the sharp edge of the garage door railing and the metal file.
Use the metal file to bevel the sharp edge of the garage door by grinding against it in a curved motion.
Assess the sharpness of the edge and bevel further if necessary.
