Einleitung
This guide will show you how to fill gaps and replace the latex caulk between a wall and a sink (or anywhere in your home that may need recaulking). The new latex caulk material will be added to the gaps using a latex caulk gun.
Was du brauchst
Use the latex paint remover spray for the areas that have remaining material along with the gaps. These areas also need to be replaced with new material.
Pull back the handle of the caulk gun.
Place the caulk tube inside it.
Twist the metal bar until it is completely inside the caulk tube and the curved handle is on top.
Add the latex to the areas you see gaps.
After finishing each side, slide your finger along the caulk to push the material inside the gaps.
Use a wipe to immediately clean the excess from the filled areas.
