Zum Hauptinhalt wechseln
How to Fix A Crooked Cabinet Door
Was du brauchst
    1. How to Fix A Crooked Cabinet Door, How to Fix A Crooked Cabinet Door: Schritt 1, Bild 1 von 1
      • Open the cabinet door, and determine where it is misaligned.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Fix A Crooked Cabinet Door: Schritt 2, Bild 1 von 1
      • Re-attach the hinge into place.
      • Soft-closing multi-adjustable hinges can snap back into their thickness plates which is the part attached to the inside of the cabinet.
      • Avoid placing your fingers near the thickness plate as its force can cause a painful pinch.
      Frag FixBot
    3. How to Fix A Crooked Cabinet Door: Schritt 3, Bild 1 von 1
      • Hold the hinge firmly against the thickness plate and tighten the screw until the hinge is no longer loose.
      • There are different methods for aligning your cabinet door depending on the screw you tighten and the direction:
      • Side-to-Side Adjustment: To move the door away from the cabinet, screw clockwise. To move the door closer to the cabinet, screw in a counterclockwise motion.
      • Up-Down Adjustment: Screw in a clockwise motion to move the door up. A counterclockwise motion will move the door down.
      Frag FixBot
    4. How to Fix A Crooked Cabinet Door: Schritt 4, Bild 1 von 1
      • The result of the tightened hinge will look as pictured.
      Frag FixBot
    5. How to Fix A Crooked Cabinet Door: Schritt 5, Bild 1 von 1
      • Measure along the top and sides of the cabinet with a balance ruler or standard ruler.
      • The result should look as pictured.
      Frag FixBot
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
CSU Los Angeles, Team 4-44, Briggs Spring 2022 Mitglied von CSU Los Angeles, Team 4-44, Briggs Spring 2022
CSULA-BRIGGS-S22S4G44
1 Mitglied
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 25
Letzte 30 Tage: 110
Insgesamt: 11,674
