Zum Hauptinhalt wechseln
How to Fix A Stripped Screw Hole
Was du brauchst
  1. How to Fix A Stripped Screw Hole, How to Fix A Stripped Screw Hole: Schritt 1, Bild 1 von 1
    • Using the toothpick as a reference, measure the depth of the screw-hole and the number of toothpicks needed to fill the screw hole.
  2. How to Fix A Stripped Screw Hole: Schritt 2, Bild 1 von 2 How to Fix A Stripped Screw Hole: Schritt 2, Bild 2 von 2
    • Next, using the wood glue, cover the area of the toothpick(s) that will fill in the screw hole.
  3. How to Fix A Stripped Screw Hole: Schritt 3, Bild 1 von 2 How to Fix A Stripped Screw Hole: Schritt 3, Bild 2 von 2
    • Place the toothpicks into the screw hole.
  4. How to Fix A Stripped Screw Hole: Schritt 4, Bild 1 von 1
    • Now, break off the exposed segment of the toothpick(s).
  5. How to Fix A Stripped Screw Hole: Schritt 5, Bild 1 von 1
    • Clean off the excess and let the wood glue dry for up to 30 minutes.
    • Recommended wood glue drying time may vary by product.
  6. How to Fix A Stripped Screw Hole: Schritt 6, Bild 1 von 2 How to Fix A Stripped Screw Hole: Schritt 6, Bild 2 von 2
    • Finally, using the screwdriver, screw the screw into the repaired screw hole.
Abschluss
Your screw should now hold secure.
Isaiah Valdez Mireles
133 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 3-24, Briggs Fall 2022 Mitglied von CSU Los Angeles, Team 3-24, Briggs Fall 2022
CSULA-BRIGGS-F22S3G24
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 59
Insgesamt: 1,553
