Einleitung
A stripped screw hole occurs when the fibers around the hole deteriorate. It can be caused by too much weight on the screw, changes in the weather, and overscrewing. This guide will instruct readers on how to repair a stripped screw hole. The instructions are beginner friendly, and the estimated time to complete is 30-35 minutes.
Was du brauchst
Using the toothpick as a reference, measure the depth of the screw-hole and the number of toothpicks needed to fill the screw hole.
Next, using the wood glue, cover the area of the toothpick(s) that will fill in the screw hole.
Your screw should now hold secure.
