Zum Hauptinhalt wechseln
How to Fix A Warped Frisbee Disc
Was du brauchst
  1. How to Fix A Warped Frisbee Disc, How to Fix A Warped Frisbee Disc: Schritt 1, Bild 1 von 2 How to Fix A Warped Frisbee Disc, How to Fix A Warped Frisbee Disc: Schritt 1, Bild 2 von 2
    • Place the frisbee disc on a flat surface with the concave side facing up. Lay a towel down flat over the frisbee.
    Frag FixBot
    Kommentar hinzufügen
  2. How to Fix A Warped Frisbee Disc: Schritt 2, Bild 1 von 1
    • Take the bowl and fill halfway full with water. Microwave until water is boiling.
    • The bowl will be hot, so handle it with care.
    Frag FixBot
  3. How to Fix A Warped Frisbee Disc: Schritt 3, Bild 1 von 1
    • Take the bowl with boiling water and place it on top of the frisbee and the towel.
    Frag FixBot
  4. How to Fix A Warped Frisbee Disc: Schritt 4, Bild 1 von 1
    • Add a textbook as a weight to sit on top of the bowl.
    • Let everything sit for 1 hour
    Frag FixBot
  5. How to Fix A Warped Frisbee Disc: Schritt 5, Bild 1 von 1
    • Remove any weights, the bowl, and the towel. Check to see if the disc is still warped.
    • If it is still warped repeat this process one more time.
    Frag FixBot
Abschluss
The time taken to fix the warping on your frisbee may vary based on how thick the plastic is.
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 30-5, Green Spring 2015 Mitglied von Cal Poly, Team 30-5, Green Spring 2015
CPSU-GREEN-S15S30G5
5 Mitglieder
32 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 22
Letzte 30 Tage: 95
Insgesamt: 10,919
