Einleitung
For frisbee owners, a warped disc is a common problem due to prolonged sun exposure or moderate wear over time. For most discs, this warping can often be undone with some gentle manipulation. This fix involves a simple set up, and then letting the frisbee sit for approximately 1 hour.
Was du brauchst
Place the frisbee disc on a flat surface with the concave side facing up. Lay a towel down flat over the frisbee.
Take the bowl and fill halfway full with water. Microwave until water is boiling.
Take the bowl with boiling water and place it on top of the frisbee and the towel.
Add a textbook as a weight to sit on top of the bowl.
Let everything sit for 1 hour
Remove any weights, the bowl, and the towel. Check to see if the disc is still warped.
The time taken to fix the warping on your frisbee may vary based on how thick the plastic is.
3 weitere Personen haben diese Anleitung absolviert.
