Einleitung
If your silverware starts to bend, there's no need to go out and buy more. This guide will show you a quick fix to repairing your silverware and bending it back to its original shape.
Was du brauchst
First, clean with soap and water all of the bent silverware.
Take the pot and fill it halfway with water.
Put the pot on the stove and heat the water till it's boiling.
After the minute is over, carefully pull out all of the silverware using pliers.
Dry off the silverware with either paper or cloth towels. Be careful not to burn yourself.
Use tools such as pliers, a hard surface, rulers, and/or hammers to reshape silverware as desired.
When your done bending the silverware to its desired shape, let the silverware cool down to stay in that shape.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
