Zum Hauptinhalt wechseln
How to Fix Broken Porch Entry Stairs
Was du brauchst
  1. How to Fix Broken Porch Entry Stairs, Stair treads and risers: Schritt 1, Bild 1 von 3 How to Fix Broken Porch Entry Stairs, Stair treads and risers: Schritt 1, Bild 2 von 3 How to Fix Broken Porch Entry Stairs, Stair treads and risers: Schritt 1, Bild 3 von 3
    • Use a pry bar to remove the pre-existing damaged wood pieces.
    • Start with the riser first.
    • Be mindful of possible rusted screws/nails.
  2. How to Fix Broken Porch Entry Stairs: Schritt 2, Bild 1 von 3 How to Fix Broken Porch Entry Stairs: Schritt 2, Bild 2 von 3 How to Fix Broken Porch Entry Stairs: Schritt 2, Bild 3 von 3
    • Remove the treads on the stairs.
  3. How to Fix Broken Porch Entry Stairs: Schritt 3, Bild 1 von 2 How to Fix Broken Porch Entry Stairs: Schritt 3, Bild 2 von 2
    • Use a measuring tape to measure the foundation where the new steps will be placed.
    • To ensure accurate measurements, make sure to repeat this step twice.
  4. How to Fix Broken Porch Entry Stairs: Schritt 4, Bild 1 von 3 How to Fix Broken Porch Entry Stairs: Schritt 4, Bild 2 von 3 How to Fix Broken Porch Entry Stairs: Schritt 4, Bild 3 von 3
    • Mark your measurements on both ends of your new weather treated wood using a measuring tape and a pencil.
    • For the best results, use a ruler to connect your marks into a straight line.
  5. How to Fix Broken Porch Entry Stairs: Schritt 5, Bild 1 von 1
    • Place the new piece of wood onto the end of a sturdy table.
    • Make sure the marked end is hanging off the edge by at least a foot.
  6. How to Fix Broken Porch Entry Stairs: Schritt 6, Bild 1 von 1
    • Use a circular saw to cut across the straight line marked on the new piece of wood.
    • Make sure the wood is secure by holding the end resting on the table the entire time.
    • Safety glasses should be worn during this step.
  7. How to Fix Broken Porch Entry Stairs: Schritt 7, Bild 1 von 2 How to Fix Broken Porch Entry Stairs: Schritt 7, Bild 2 von 2
    • Place the new piece of wood (riser) on the steps to ensure that it fits.
    • Use a leveler to make sure that it is level.
  8. How to Fix Broken Porch Entry Stairs: Schritt 8, Bild 1 von 3 How to Fix Broken Porch Entry Stairs: Schritt 8, Bild 2 von 3 How to Fix Broken Porch Entry Stairs: Schritt 8, Bild 3 von 3
    • Secure your wood piece (riser) into place using a drill and galvanized screws.
    • Create two pilot holes with the correct drill bit.
    • Secure the wood (riser) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
  9. How to Fix Broken Porch Entry Stairs: Schritt 9, Bild 1 von 1
    • Make sure your wood piece (tread) fits into place and is level.
    • For the most accurate results, it is important to use a large level.
  10. How to Fix Broken Porch Entry Stairs: Schritt 10, Bild 1 von 3 How to Fix Broken Porch Entry Stairs: Schritt 10, Bild 2 von 3 How to Fix Broken Porch Entry Stairs: Schritt 10, Bild 3 von 3
    • Secure your wood piece (tread) into place using a drill and galvanized screws.
    • Create three pilot holes with the correct drill bit.
    • Secure the wood (tread) into place by drilling 2" galvanized Phillips head screws into the pilot holes.
  11. How to Fix Broken Porch Entry Stairs: Schritt 11, Bild 1 von 1
    • Repeat steps 8-10 for the remaining stairs.
    • For the best results, follow this guide thoroughly for each stair.
Abschluss
To reassemble your old stairs, follow these instructions in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
Kayla Unsworth
240 Reputation
1 Anleitung geschrieben
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 Mitglied von USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018
USFSM-STEWART-S18S1G1
15 Mitglieder
26 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 28
Letzte 30 Tage: 132
Insgesamt: 8,440
