Zum Hauptinhalt wechseln
How to Fix Broken Powder Make-up
Was du brauchst
    1. How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: Schritt 1, Bild 1 von 3 How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: Schritt 1, Bild 2 von 3 How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: Schritt 1, Bild 3 von 3
      • Using the metal butter knife or metal spudger, break up the entire pan of powder into fine pieces.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Fix Broken Powder Make-up: Schritt 2, Bild 1 von 3 How to Fix Broken Powder Make-up: Schritt 2, Bild 2 von 3 How to Fix Broken Powder Make-up: Schritt 2, Bild 3 von 3
      • Pour a small amount of rubbing alcohol into the cap.
      • Slowly add the rubbing alcohol from the cap to the powder and mix it with the knife as you go.
      • Do not use more than two caps worth of rubbing alcohol.
      Frag FixBot
    3. How to Fix Broken Powder Make-up: Schritt 3, Bild 1 von 2 How to Fix Broken Powder Make-up: Schritt 3, Bild 2 von 2
      • The powder will become creamy with no chunks or bumps. Use the side of the knife to smooth over the top surface.
      Frag FixBot
    4. How to Fix Broken Powder Make-up: Schritt 4, Bild 1 von 1
      • To completely smooth over the top surface, use a clean finger to push out the edges and even out the surface.
      Frag FixBot
    5. How to Fix Broken Powder Make-up: Schritt 5, Bild 1 von 1
      • Wait a few hours to let dry before closing the lid. The rubbing alcohol will evaporate, leaving you with a pressed solid ready for re-use.
      • If the powder is not fully dry, let it sit for another hour and continue to check back.
      Frag FixBot
Abschluss
These steps can be used to fix any type of powder makeup (ie. eyeshadows, blush, etc.)
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 30-3, Green Spring 2015 Mitglied von Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
4 Mitglieder
72 Anleitungen geschrieben
1 Kommentar zur Anleitung
It's also good to mash the surface down with something flat like a coin on top of a paper towel, while it's still a little malleable. This way, you get an even, similar texture as when it was new.
Great guide!
Kim Arre - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 19
Letzte 30 Tage: 51
Insgesamt: 2,493
