Zum Hauptinhalt wechseln
How to Fix Cracked Glassware with Food Safe Resin
Was du brauchst
  1. How to Fix Cracked Glassware with Food Safe Resin, How to Fix Cracked Glassware with Food Safe Resin: Schritt 1, Bild 1 von 1
    • Lay a garbage bag out on your workstation and put on disposable gloves.
    • Using separate cups, measure the resin and hardener to an exact 1:1 ratio.
    • Always wear gloves and ensure your work area is well-ventilated while working with resin. You may also want to wear safety glasses to protect your eyes.
    Frag FixBot
    Kommentar hinzufügen
  2. How to Fix Cracked Glassware with Food Safe Resin: Schritt 2, Bild 1 von 2 How to Fix Cracked Glassware with Food Safe Resin: Schritt 2, Bild 2 von 2
    • Add the resin and hardener to a container or bowl to mix the solution.
    • Scrape the sides of the measuring cups to ensure that both liquids are fully incorporated.
    Frag FixBot
  3. How to Fix Cracked Glassware with Food Safe Resin: Schritt 3, Bild 1 von 1
    • Use the mixing stick to stir the resin and hardener for at least three minutes.
    • Scrape the sides and bottom while mixing.
    Frag FixBot
  4. How to Fix Cracked Glassware with Food Safe Resin: Schritt 4, Bild 1 von 2 How to Fix Cracked Glassware with Food Safe Resin: Schritt 4, Bild 2 von 2
    • Dip one end of the Q-Tip into the resin mixture. Submerging is not necessary; ensure the tip is coated enough to cover the surface of the crack.
    • Apply the resin mixture to the affected area(s), covering the crack completely. Cover both the inside and outside of the crack if necessary.
    • Be careful of loose shards of glass.
    Frag FixBot
  5. How to Fix Cracked Glassware with Food Safe Resin: Schritt 5, Bild 1 von 1
    • Allow the resin to cure for at least eight hours.
    Frag FixBot
  6. How to Fix Cracked Glassware with Food Safe Resin: Schritt 6, Bild 1 von 2 How to Fix Cracked Glassware with Food Safe Resin: Schritt 6, Bild 2 von 2
    • Place the Q-tip and leftover resin into a disposable, sealable plastic bag.
    • Allow it to cure for 8+ hours before disposing.
    • Do NOT pour resin down the drain or into the sink.
    • Flip the measuring and mixing cups over the trash bag to remove any excess resin or hardener.
    Frag FixBot
  7. How to Fix Cracked Glassware with Food Safe Resin: Schritt 7, Bild 1 von 2 How to Fix Cracked Glassware with Food Safe Resin: Schritt 7, Bild 2 von 2
    • When the resin has finished curing, use an alcohol wipe to remove any excess from the surface of your glass item.
    • If the resin is too hard, use a craft blade to gently scrape off the excess.
    • Exercise caution when working with blades.
    Frag FixBot
  8. How to Fix Cracked Glassware with Food Safe Resin: Schritt 8, Bild 1 von 2 How to Fix Cracked Glassware with Food Safe Resin: Schritt 8, Bild 2 von 2
    • Pour warm water to ensure that the glassware is heat-safe and that the cracks are completely sealed.
    • Wash the glassware gently and thoroughly to remove any excess resin applied on the inside.
    Frag FixBot
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
Hana
189 Reputation
1 Anleitung geschrieben
Austin Community College, Team 29-6, Watkins Fall 2024 Mitglied von Austin Community College, Team 29-6, Watkins Fall 2024
AUSTINCC-WATKINS-F24S29G6
1 Mitglied
1 Kommentar zur Anleitung
After applying resin, can I heat the item in open flame source ?
Jaggermeister Asti - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 49
Letzte 30 Tage: 262
Insgesamt: 2,870
