Einleitung
If your PlayStation 2 Slim (model SCPH-70012) struggles to read discs, skips during gameplay, or displays "Disc Read Error" messages, the issue is often caused by a misaligned disc drive or weakened laser. This guide will show you how to open the PS2 Slim, clean and align the disc drive, and carefully adjust the laser potentiometer to restore reliable disc reading.
The laser assembly in the PS2 Slim reads both CD and DVD media, and over time, its alignment or resistance values can drift, causing poor reading performance. Cleaning and adjusting these components can significantly extend the life of your console without replacing any parts.
Before you begin, unplug all cables and ensure the console is powered off. Handle internal parts gently, especially ribbon cables and the laser lens, as they are delicate and easily damaged. Avoid touching the lens directly, and work slowly when adjusting the potentiometer since over-turning it can permanently damage the laser.
This repair requires only basic tools and careful attention to small components. No soldering or advanced electronics work is needed.
By following this guide, you'll be able to fix disc read errors, improve load times, and extend the lifespan of your PlayStation 2 Slim.
Was du brauchst
Before beginning, unplug the power cable, AV cables, and any controllers or memory cards.
Flip the console upright and check the label to confirm your model is SCPH-70012.
Turn the console upside down so the ports face you.
Use a small flathead screwdriver or spudger to carefully pry up the six square screw covers on the bottom panel.
Set the covers aside in order.
Use a Phillips #1 screwdriver to remove the six 4.0 mm screws from the bottom shell.
Use an opening tool to gently separate the top cover from the base.
Start from the front edge near the controller ports and work the opening tool around the perimeter of the device to release the clips that hold the top and bottom together.
Dip a cotton swab in isopropyl alcohol and gently clean the right-hand guide rail and sled track.
Wipe away any old grease or dust buildup to allow the laser sled to move properly.
Carefully rotate the worm gear at the top-right of the disc drive to move the laser sled to the middle of its travel range.
Use a fine tip marker to mark each of the four silver posts around the spindle motor. These posts, secured by 4.0 mm screws, control the disc drive's tilt and height.
Turn one post just a few degrees at a time to slightly change disc height or tilt.
Test the console after each small change until discs read consistently.
Use a Phillips #00 screwdriver to remove the three screws securing the laser sled and guide rail in place.
Start with the right side screw, then move to the left as shown in the photos.
Lift the laser assembly a few millimeters to see the two small laser potentiometers on the green circuit board.
Use a multimeter to measure the resistance across the outer and middle terminals of the DVD potentiometer.
Record the original reading (in kΩ or Ω) before making any changes.
Use a precision flathead screwdriver to turn the DVD potentiometer clockwise by no more than 1-2 degrees.
