Einleitung
Water leaks for the Keurig B70 Brewing System are sometimes caused by an internal disconnection of the water pump and reservoir. Use this guide to open the Keurig and reseat the water pump.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Move the brewer so that the metal baseplate is easily accessible.
Remove the five silver 4 mm Phillips #2 screws from the baseplate.
Using a spudger, gently pry the metal baseplate from the brewer.
Gently set down the baseplate.
Remove the two silver 4mm Phillips #2 screws that hold the water pump in place.
Ein weiterer Nutzer hat diese Anleitung absolviert.
