Zum Hauptinhalt wechseln
Synchronisationsprobleme am linken Joy-Con lösen
Was du brauchst
Videoanleitungen
Abschluss
Um dein Gerät wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge.
12 weitere Personen haben diese Anleitung absolviert.
en de
100%
Hier starten ›
Taylor Dixon
71.789 Reputation
94 Anleitungen geschrieben
7 Kommentare zur Anleitung
What thickness of conductive foam should I choose? There are 3 sizes: 3mm/0.12, 5mm/0.20", 10mm/0.39"
maximaleks - Antwort
The space is ~9 mm wide, so I would go with the 10 mm size and you can trim it down if you need to!
Taylor Dixon -
I've got the same problem but with the right joycon but I don't know where the wireless card is, please help
Nathan Currie - Antwort
Hello I opened up my left joycon and saw conductive foam inside already! I replaced it with one that I bought on amazon (I made sure it was actually conductive foam). But it still won’t sync. Any ideas? Could it be that little solder bubble that connects to the antenna has gone bad? Should I try to reflow it? I also checked to see if any capacitors in the top of the board were shorted and none of them were. If you have any ideas I would be happy to hear!
Chaim Bendahan - Antwort
I opened my left Joycon and found that there is no antenna area near the joystick compartment. It’s just an empty space what should I do, I have the conductive foam but obviously don’t know where to place.
Omar Gonzalez - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 36
Letzte 7 Tage: 134
Letzte 30 Tage: 727
Insgesamt: 45,657
