Zum Hauptinhalt wechseln
How to Fix Loose Stitching on a Blanket
Was du brauchst
  1. How to Fix Loose Stitching on a Blanket, How to Fix Loose Stitching on a Blanket: Schritt 1, Bild 1 von 1
    • Remove the loose threading using a pair of sewing scissors.
  2. How to Fix Loose Stitching on a Blanket: Schritt 2, Bild 1 von 1
    • Pin down the edges of the blanket one finger width apart using the safety pins.
  3. How to Fix Loose Stitching on a Blanket: Schritt 3, Bild 1 von 1
    • Choose the color of thread that best matches the original thread color.
  4. How to Fix Loose Stitching on a Blanket: Schritt 4, Bild 1 von 1
    • Push the thread through the eye of the needle.
  5. How to Fix Loose Stitching on a Blanket: Schritt 5, Bild 1 von 1
    • Begin sewing the blanket, making sure the stiches aren't too close together.
    • For this photo, a blanket stitch was used.
  6. How to Fix Loose Stitching on a Blanket: Schritt 6, Bild 1 von 2 How to Fix Loose Stitching on a Blanket: Schritt 6, Bild 2 von 2
    • When finished sewing, cut the remaining thread.
    • Tie the thread in a knot to close off the blanket.
  7. How to Fix Loose Stitching on a Blanket: Schritt 7, Bild 1 von 1
    • Remove all the extra thread remaining on the blanket.
Ziellinie
Jacob
145 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 33
Letzte 30 Tage: 72
Insgesamt: 471
