Zum Hauptinhalt wechseln
How to Fix Scratches on a Steel Watch
Was du brauchst
  1. How to Fix Scratches on a Steel Watch, How to Fix Scratches on a Steel Watch: Schritt 1, Bild 1 von 1
    • Fill any container up with water.
  2. How to Fix Scratches on a Steel Watch: Schritt 2, Bild 1 von 1
    • Grab any soft-bristled brush around for your convenience.
  3. How to Fix Scratches on a Steel Watch: Schritt 3, Bild 1 von 3 How to Fix Scratches on a Steel Watch: Schritt 3, Bild 2 von 3 How to Fix Scratches on a Steel Watch: Schritt 3, Bild 3 von 3
    • Dip the toothbrush in the water.
    • Brush along the crystal, bezel, and case in a circular motion.
    • Brush the bracelet in a linear motion back-and-forth.
    • Make sure to brush over the crevices of the bracelet for an optimal clean.
  4. How to Fix Scratches on a Steel Watch: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Microfiber Cleaning Cloths
    $3.99
    Kaufen
    • Dry the watch with a microfiber towel by pinching your fingers together in a back-and-forth motion.
  5. How to Fix Scratches on a Steel Watch: Schritt 5, Bild 1 von 1
    • Use the abrasive side of a sponge to brush the watch, following the same steps mentioned in Step 3.
    • Do not brush over the crystal with the sponge.
    • Apply minimal pressure to the sponge when brushing the watch.
  6. How to Fix Scratches on a Steel Watch: Schritt 6, Bild 1 von 1
    • Fold the metal polishing cloth in half.
    • Hold the corner of the cloth along your index finger.
  7. How to Fix Scratches on a Steel Watch: Schritt 7, Bild 1 von 1
    • Brush off all the scratches on the watch using a back-and-forth motion with great pressure to ensure effectiveness.
    • Perform the process as many times as needed.
    • Do not brush over the crystal.
Ziellinie
Youssefmo
195 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 2-26, Briggs Fall 2022 Mitglied von CSU Los Angeles, Team 2-26, Briggs Fall 2022
CSULA-BRIGGS-F22S2G26
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 12
Letzte 30 Tage: 39
Insgesamt: 575
