Einleitung
Repair snagged jeans with simple skills, such as threading a needle or tying a knot. Repairing the snagged denim will prevent further tearing, and will make the denim more visually appealing.
Was du brauchst
Identify the snag that you would like to correct.
Insert the sharp end of your ballpoint needle through the centre of the snag.
Carefully turn the jeans inside out, while maintaining the placement of the ballpoint needle.
Allow the ballpoint needle to stand vertically. This will happen naturally.
Take your No. 18 tapestry needle and gently maneuver all of the loose strings from the snagged denim to the inside of the jeans. You will position your needle to pull the loose strings upward.
String the No. 18 tapestry needle with your thread.
Tie both ends of the thread to form a small, tight knot.
Once you've removed the excess thread, take a small amount of fabric adhesive, and rub it against the knot you made to confident the snagged denim. The adhesive will secure the loose strings inside the denim.
Apply the adhesive so that the knot is stuck to the surface of the denim.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
wtf?! make your nails first!
Exactly how do you determine which thread to pull on the reverse side of jeans??!! It was not obvious, and this ‘how to’ didn’t explain that essential part. Struggled for 15 min, then went on to another youtube how-to that worked easily (https://www.youtube.com/watch?v=--tHHF_M... ). With this other tutorial, I fixed two pairs in under 10 min.
I did have to try to find the strings (that were snagged) to pull through but with a little patience it worked beautifully! Thanks for the tutorial! I was proud of myself for finally using my little sowing kit! And people are jerks with the comments!
Thank you! This was helpful! I thought about fabric adhesive to secure the loose ends on the inside of the jeans, but so glad to know that you recommend it! Great photos!
Cheri - 5/31/2021
