Zum Hauptinhalt wechseln
How to Fix Subwoofer Amplifiers
Was du brauchst
  1. How to Fix Subwoofer Amplifiers, How to Fix Subwoofer Amplifiers: Schritt 1, Bild 1 von 1
    • Disconnect the black (negative) cable from the battery to disable the electrical connection.
    • Always disconnect the negative cable before the positive cable.
    • Disconnect the red (positive) cable from the battery to disable the electrical connection.
  2. How to Fix Subwoofer Amplifiers: Schritt 2, Bild 1 von 1
    • Pull the fuses out and make sure that they were not blown.
  3. How to Fix Subwoofer Amplifiers: Schritt 3, Bild 1 von 1
    • Undo and remove all wires from the amplifier.
    • This should include the battery wire, ground wire, speaker wires, remote wire from the radio, and sound wires that also come from radio.
    • Remove and check the fuse from the amp to make sure it is not a blown fuse.
  4. How to Fix Subwoofer Amplifiers: Schritt 4, Bild 1 von 1
    • Strip the wires so they can have a better connection.
    • Twist the exposed copper wiring to make it easier to connect to the amplifier.
  5. How to Fix Subwoofer Amplifiers: Schritt 5, Bild 1 von 1
    • Replace the wires in their designated slots.
    • Tighten the clamps all the way down.
    • Wiggle and tug on the wires to make sure they are secured nice and tight.
  6. How to Fix Subwoofer Amplifiers: Schritt 6, Bild 1 von 1
    • Replace the battery wires.
    • The red wire should go to the positive side, and the black wire should go to the negative side.
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
Luke Turner
154 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 16
Letzte 30 Tage: 64
Insgesamt: 831
