Zum Hauptinhalt wechseln
How to Fix Unresponsive Keys for an Optimus Concertmate 980
Was du brauchst
  1. How to Fix Unresponsive Keys for an Optimus Concertmate 980, How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 1, Bild 1 von 2 How to Fix Unresponsive Keys for an Optimus Concertmate 980, How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 1, Bild 2 von 2
    • Test all keys to identify the ones that are not functional.
    Frag FixBot
    Kommentar hinzufügen
  2. How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 2, Bild 1 von 3 How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 2, Bild 2 von 3 How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 2, Bild 3 von 3
    • Flip the piano to its backside.
    • Remove all the screws on the back of the piano using a Phillips #0 screwdriver.
    Frag FixBot
  3. How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 3, Bild 1 von 3 How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 3, Bild 2 von 3 How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 3, Bild 3 von 3
    • Remove the back metal plate.
    • Flip the piano to its front before the next step.
    Frag FixBot
  4. How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 4, Bild 1 von 2 How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 4, Bild 2 von 2
    • Lift up the top panel from the back.
    • The panel won't come off completely due to the cables connected.
    Frag FixBot
  5. How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 5, Bild 1 von 2 How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 5, Bild 2 von 2
    • Reattach any loose cables.
    • Clean any dust from the top of the keys with a vacuum or cotton swab.
    Frag FixBot
  6. How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 6, Bild 1 von 2 How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 6, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove all the screws attached to the top of the keys.
    Frag FixBot
  7. How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 7, Bild 1 von 3 How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 7, Bild 2 von 3 How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 7, Bild 3 von 3
    • Remove the white keys by pulling them from the top and sliding them down.
    • To remove the black keys, pull on the keys first to pull off, then remove the keys entirely.
    Frag FixBot
  8. How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 8, Bild 1 von 3 How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 8, Bild 2 von 3 How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 8, Bild 3 von 3
    • Clean all the dust under the keys.
    • Clean around the orange tips, making sure they are upright.
    Frag FixBot
  9. How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 9, Bild 1 von 3 How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 9, Bild 2 von 3 How to Fix Unresponsive Keys for an Optimus Concertmate 980: Schritt 9, Bild 3 von 3
    • Place the keys in the same order as you took them out.
    • Using a Phillips screwdriver, replace all the screws in the same places as you removed them.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Randy Coronado
169 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 3-19, Harris Fall 2024 Mitglied von CSU Los Angeles, Team 3-19, Harris Fall 2024
CSULA-HARRIS-F24S3G19
1 Mitglied
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 27
Insgesamt: 409
