Zum Hauptinhalt wechseln
How to Fix a Broken Ceramic Vase
Was du brauchst
  1. How to Fix a Broken Ceramic Vase, How to Fix a Broken Ceramic Vase: Schritt 1, Bild 1 von 1
    • Examine the damage to the vase. Determine how large the cracks and chips are.
    • Smaller cracks can be fixed with a ceramic adhesive, while larger cracks may require putty.
  2. How to Fix a Broken Ceramic Vase: Schritt 2, Bild 1 von 1
    • Sand the broken edges and cracked pieces on the vase with a sander block.
  3. How to Fix a Broken Ceramic Vase: Schritt 3, Bild 1 von 2 How to Fix a Broken Ceramic Vase: Schritt 3, Bild 2 von 2
    • Apply ceramic adhesive to the broken pieces and press them together for two minutes.
  4. How to Fix a Broken Ceramic Vase: Schritt 4, Bild 1 von 1
    • Secure masking tape over the cracks and let the vase dry for 3 hours.
  5. How to Fix a Broken Ceramic Vase: Schritt 5, Bild 1 von 1
    • After the vase dries, clean the areas with a cloth where chunks of ceramic are missing.
  6. How to Fix a Broken Ceramic Vase: Schritt 6, Bild 1 von 2 How to Fix a Broken Ceramic Vase: Schritt 6, Bild 2 von 2
    • Use a chisel scraper to fill in the missing areas with putty and allow it to dry completely.
  7. How to Fix a Broken Ceramic Vase: Schritt 7, Bild 1 von 1
    • Select a paint that matches the vase and use a soft paintbrush to paint the dry putty wall.
  8. How to Fix a Broken Ceramic Vase: Schritt 8, Bild 1 von 1
    • Let the paint dry for one hour on the vase and your repair is finished.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jennifer Ford
184 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 36
Letzte 30 Tage: 147
Insgesamt: 1,214
