Einleitung
This instruction guide is your one-stop solution for fixing a broken strap on a strapback hat. Once the strap is broken, it can be very discouraging as the hat is completely unusable. However, there is no need to throw it out and contribute to growing textile waste. This instruction guide will lead you through eleven simple steps to bring your strapback hat back to life.
Was du brauchst
Measure the thread.
Cut the thread at desired length.
Pull the thread through the needle until both ends of the thread meet.
Tie a knot at the end of the thread.
Starting on the inside of the hat, poke the needle through the cap and loose strap.
Pull the needle through the fabric and out the other end.
Move the needle a few millimeters to the left and poke the needle through the front of the hat.
Pull the needle out on the other end.
Congratulations! With some simple hand sewing, you were able to fix the broken strap on your hat.
