Zum Hauptinhalt wechseln
How to Fix a Broken Toilet Paper Holder
Was du brauchst
  1. How to Fix a Broken Toilet Paper Holder, How to Fix a Broken Toilet Paper Holder: Schritt 1, Bild 1 von 1
    • As you can tell, the left holder is loose. Replacing the anchor is much needed.
  2. How to Fix a Broken Toilet Paper Holder: Schritt 2, Bild 1 von 1
    • Remove the Allen screw under each holder.
    • I used a 1/6" Allen bit because that is what fit my toilet paper holder's Allen screw. Use the bit according to the screw available.
    • If the screw size is unknown, I would recommend buying a pack with several Allen bits and trying each until the right one is found.
  3. How to Fix a Broken Toilet Paper Holder: Schritt 3, Bild 1 von 3 How to Fix a Broken Toilet Paper Holder: Schritt 3, Bild 2 von 3 How to Fix a Broken Toilet Paper Holder: Schritt 3, Bild 3 von 3
    • After unscrewing the holder, take it off and begin unscrewing the screws in the wall. The type of screwdriver depends on the screws used.
    • Remove the clip after removing all screws. You should be left with two big holes and two small holes in the wall.
  4. How to Fix a Broken Toilet Paper Holder: Schritt 4, Bild 1 von 2 How to Fix a Broken Toilet Paper Holder: Schritt 4, Bild 2 von 2
    • Remove the existing anchor and drill the top hole with the 5/16" drill bit. This will make space for the new anchor to be placed.
    • Pinch the new 3/8"-1/2" anchor, place it into the top hole, and push it to be level with the wall.
  5. How to Fix a Broken Toilet Paper Holder: Schritt 5, Bild 1 von 2 How to Fix a Broken Toilet Paper Holder: Schritt 5, Bild 2 von 2
    • After placing the new anchor in, align the clip accordingly and proceed to screw in the anchor, starting with the top hole and then the bottom hole.
    • You have the option to use a either a screwdriver or drill (head based on the screws in possession).
  6. How to Fix a Broken Toilet Paper Holder: Schritt 6, Bild 1 von 2 How to Fix a Broken Toilet Paper Holder: Schritt 6, Bild 2 von 2
    • When you have completed the previous step for both sides, place the toilet paper holder in place and re-screw the Allen screw until both holders feel stiff.
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
York University, Team S1-G9, Allen Summer 2020 Mitglied von York University, Team S1-G9, Allen Summer 2020
YORK-ALLEN-SU20S1G9
1 Mitglied
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 52
Letzte 30 Tage: 308
Insgesamt: 24,007
