Einleitung
This guide will thoroughly explain how to easily repair a zipper that is broken. No special requirements needed; just needle-nose pliers, scissors, and a needle and thread!
Was du brauchst
Take the needle nose pliers and remove the metal or plastic stopper at the end of the zipper.
Zip the zipper all the way down to the last set of teeth.
Thread the needle.
Sew up the area where the metal or plastic stopper used to reside.
Take the scissors and cut off the excess thread. Get as close to the knot as you can without cutting it off.
10 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Not helpful. Suppose if the slider part broke and is now now. Now what?
