Zum Hauptinhalt wechseln
How to Fix a Button on an Umbrella
Was du brauchst
  1. How to Fix a Button on an Umbrella, How to Fix a Button on an Umbrella: Schritt 1, Bild 1 von 1
    • Remove the 1.1 mm screw that fixates the handle to the umbrella using a Phillips #1 screwdriver.
  2. How to Fix a Button on an Umbrella: Schritt 2, Bild 1 von 2 How to Fix a Button on an Umbrella: Schritt 2, Bild 2 von 2
    • Remove the umbrella handle by pushing on the eject push-up button.
  3. How to Fix a Button on an Umbrella: Schritt 3, Bild 1 von 2 How to Fix a Button on an Umbrella: Schritt 3, Bild 2 von 2
    • Place a thin malleable metal in between the button’s connection to the metal projection.
  4. How to Fix a Button on an Umbrella: Schritt 4, Bild 1 von 2 How to Fix a Button on an Umbrella: Schritt 4, Bild 2 von 2
    • Apply permanent adhesive to secure the thin metal to the button's walls. Wait a few minutes for the adhesive to dry.
  5. How to Fix a Button on an Umbrella: Schritt 5, Bild 1 von 1
    • Verify that the button is firmly fixated to the metal ejector.
  6. How to Fix a Button on an Umbrella: Schritt 6, Bild 1 von 2 How to Fix a Button on an Umbrella: Schritt 6, Bild 2 von 2
    • Proceed to push down on the button while placing the handle.
    • The button goes through the handles button crevice.
  7. How to Fix a Button on an Umbrella: Schritt 7, Bild 1 von 1
    • Verify that the button is firmly fixated on the metal ejector.
  8. How to Fix a Button on an Umbrella: Schritt 8, Bild 1 von 1
    • Pound a nail with a hammer to prevent the opening system from turning.
  9. How to Fix a Button on an Umbrella: Schritt 9, Bild 1 von 1
    • Return the screw to fixate the handle to the umbrella.
Abschluss
Maria Rosado
169 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 24
Letzte 7 Tage: 163
Letzte 30 Tage: 548
Insgesamt: 15,254
