Einleitung
This guide will outline the steps to fix a broken carabiner with a misaligned gate. If your carabiner is used for personal use but has a gate that won’t securely snap into place or is crooked, this guide will help you fix it.
So long as the rivet pin isn’t broken or bent, the carabiner gate should be able to be fixed using this guide.
Disclaimer: Carabiners used for safety measures - firefighting, climbing, etc. - should not be used after a failure such as broken gate. Even after a carabiner is repaired, it should not be used for any purpose that can potentially put a person in danger. Carabiners used for safety should be replaced if broken in any way, though if utilized for personal use, fixing it is an easy solution.
Was du brauchst
Position the carabiner so that the gate is pushed forward past the nose and the latch is hanging out.
The gate should now snap back into position securely. If it does not, repeat the process.
Be sure that the rivet pin was not bent or broken in the act of guiding the gate back to its original position.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Thank you for tutorial I was autism and bent it.
Was gonna throw the old one away but this helped. Good as new now, thanks!
