Zum Hauptinhalt wechseln
How to Fix a Carabiner
Was du brauchst
  1. How to Fix a Carabiner, How to Fix a Carabiner: Schritt 1, Bild 1 von 1
    • Position the carabiner so that the gate is pushed forward past the nose and the latch is hanging out.
  2. How to Fix a Carabiner: Schritt 2, Bild 1 von 1
    • Position the pliers between the rivet pin.
    • The rivet pin is a flat rectangle metal piece poking out of the hinges.
  3. How to Fix a Carabiner: Schritt 3, Bild 1 von 1
    • Gently but firmly squeeze the rivet pin behind the hinge.
  4. How to Fix a Carabiner: Schritt 4, Bild 1 von 2 How to Fix a Carabiner: Schritt 4, Bild 2 von 2
    • Push the gate back, so that it is behind the nose.
    • Be sure to push the gate slowly and carefully, to avoid unnecessary jerking around, which could potentially break the carabiner further.
  5. How to Fix a Carabiner: Schritt 5, Bild 1 von 1
    • Position the gate back to the original position behind the nose.
  6. How to Fix a Carabiner: Schritt 6, Bild 1 von 1
    • The gate should now snap back into position securely. If it does not, repeat the process.
    • Be sure that the rivet pin was not bent or broken in the act of guiding the gate back to its original position.
Ziellinie
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Thank you for tutorial I was autism and bent it.
Vehicular manslaughter - Antwort
Was gonna throw the old one away but this helped. Good as new now, thanks!
Maksim Krotov - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 18
Letzte 7 Tage: 183
Letzte 30 Tage: 645
Insgesamt: 19,414
