Zum Hauptinhalt wechseln
How to Fix a Carpet Dent
Was du brauchst
  1. How to Fix a Carpet Dent, How to Fix a Carpet Dent: Schritt 1, Bild 1 von 1
    • First decide what carpet dent you would like to fix.
  2. How to Fix a Carpet Dent: Schritt 2, Bild 1 von 1
    • Rake the carpet with the fork to break up the fibers in the carpet.
  3. How to Fix a Carpet Dent: Schritt 3, Bild 1 von 1
    • Submerge your white towel into the bowl of cold water.
  4. How to Fix a Carpet Dent: Schritt 4, Bild 1 von 1
    • Place the damp towel over the carpet dent and push down.
  5. How to Fix a Carpet Dent: Schritt 5, Bild 1 von 1
    • Put a steamer or clothes iron on top of the white towel so the heat from the steam can lift the carpet fibers.
  6. How to Fix a Carpet Dent: Schritt 6, Bild 1 von 1
    • Lift up your towel and see your brand new carpet!
    • The carpet may take an hour or two to fully dry, so be careful not to step on the wet area right away!
Abschluss
In conclusion, this is an incredibly easy process which takes very little time and effort. Very helpful if you have just rearranged a room and do not want noticeable carpet dents.
Abigail Gaines
133 Reputation
1 Anleitung geschrieben
Texas Tech, Team S3-G1, Cowan Spring 2021 Mitglied von Texas Tech, Team S3-G1, Cowan Spring 2021
TTU-COWAN-S21S3G1
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 25
Insgesamt: 351
