Einleitung
In this guide I will document the process of fixing those pesky indentations in your carpet caused by pressure from heavy furniture. This process is simple, easy, and fast! If you do not want people seeing your carpet dent and need a fast fix, then this is the right guide for you! You will start by raking the carpet to separate the fibers, next you will submerge your white towel in the cold water, and dampen your carpet while pushing down. Next, you will take your steamer or iron and put heat on top of white towel and effected area, lift up and see your results!
Was du brauchst
Put a steamer or clothes iron on top of the white towel so the heat from the steam can lift the carpet fibers.
In conclusion, this is an incredibly easy process which takes very little time and effort. Very helpful if you have just rearranged a room and do not want noticeable carpet dents.
