Zum Hauptinhalt wechseln
How to Fix a Chair Armrest
Was du brauchst
    1. How to Fix a Chair Armrest, How to Fix a Chair Armrest: Schritt 1, Bild 1 von 3 How to Fix a Chair Armrest, How to Fix a Chair Armrest: Schritt 1, Bild 2 von 3 How to Fix a Chair Armrest, How to Fix a Chair Armrest: Schritt 1, Bild 3 von 3
      • Remove the armrest from the chair using a hex wrench screwdriver and a drill to remove the screws.
      • You can also use a screwdriver instead of a drill.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Fix a Chair Armrest: Schritt 2, Bild 1 von 2 How to Fix a Chair Armrest: Schritt 2, Bild 2 von 2
      • This is the chair that we will fix, and the armrest that was broken.
      Frag FixBot
    3. How to Fix a Chair Armrest: Schritt 3, Bild 1 von 2 How to Fix a Chair Armrest: Schritt 3, Bild 2 von 2
      • Sand just the inside tip of the armrest as shown.
      Frag FixBot
    4. How to Fix a Chair Armrest: Schritt 4, Bild 1 von 2 How to Fix a Chair Armrest: Schritt 4, Bild 2 von 2
      • Apply a little bit of glue on the part that you sanded.
      • It is fine if you do not want to use glue.
      Frag FixBot
    5. How to Fix a Chair Armrest: Schritt 5, Bild 1 von 2 How to Fix a Chair Armrest: Schritt 5, Bild 2 von 2
      • Put the screw washer on the screw.
      Frag FixBot
    6. How to Fix a Chair Armrest: Schritt 6, Bild 1 von 3 How to Fix a Chair Armrest: Schritt 6, Bild 2 von 3 How to Fix a Chair Armrest: Schritt 6, Bild 3 von 3
      • Insert the screw inside the hole on the inside of the chair body.
      • Have another person attach the armrest and then screw it with your hand.
      Frag FixBot
    7. How to Fix a Chair Armrest: Schritt 7, Bild 1 von 2 How to Fix a Chair Armrest: Schritt 7, Bild 2 von 2
      • Insert the screw into the end of the armrest, attaching it to the edge of the back of the chair using a drill.
      • You may also use a screwdriver instead of a drill.
      Frag FixBot
    8. How to Fix a Chair Armrest: Schritt 8, Bild 1 von 3 How to Fix a Chair Armrest: Schritt 8, Bild 2 von 3 How to Fix a Chair Armrest: Schritt 8, Bild 3 von 3
      • Tighten up the screw with a hex wrench screwdriver.
      Frag FixBot
    9. How to Fix a Chair Armrest: Schritt 9, Bild 1 von 2 How to Fix a Chair Armrest: Schritt 9, Bild 2 von 2
      • All done! Now your armrest should feel securely attached to the chair.
      Frag FixBot
Abschluss
These are moderate step to fix your chair armrest.
Eine weitere Person hat diese Anleitung absolviert.
Deviny
196 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S1-G2, O'Connell Spring 2021 Mitglied von UMass Dartmouth, Team S1-G2, O'Connell Spring 2021
UMASSD-O'CONNELL-S21S1G2
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 68
Insgesamt: 3,779
