Zum Hauptinhalt wechseln
How to Fix a Corroded Outdoor Water Spigot
Was du brauchst
  1. How to Fix a Corroded Outdoor Water Spigot, How to Fix a Corroded Outdoor Water Spigot: Schritt 1, Bild 1 von 1
    • Rinse the outside ring of the spigot off with water.
  2. How to Fix a Corroded Outdoor Water Spigot: Schritt 2, Bild 1 von 1
    • Once wet, apply 1 tbsp. of Bar Keepers Friend soft cleanser to the area(s) that has any built up residue.
  3. How to Fix a Corroded Outdoor Water Spigot: Schritt 3, Bild 1 von 1
    • Let the solution sit for 5-10 minutes.
  4. How to Fix a Corroded Outdoor Water Spigot: Schritt 4, Bild 1 von 1
    • Brush the cleanser that is on the spigot with a wire metal brush until you notice that the residue is gone.
  5. How to Fix a Corroded Outdoor Water Spigot: Schritt 5, Bild 1 von 1
    • Rinse the spigot off completely with water.
  6. How to Fix a Corroded Outdoor Water Spigot: Schritt 6, Bild 1 von 1
    • Using plumbers tape, wrap around the spigot once ensuring that is it fully covered.
  7. How to Fix a Corroded Outdoor Water Spigot: Schritt 7, Bild 1 von 1
    • Apply the connection for your garden hose securely to the spigot.
  8. How to Fix a Corroded Outdoor Water Spigot: Schritt 8, Bild 1 von 1
    • Turn on water to ensure there are no leaks/water sprays.
Abschluss
Morgan Fluegel
157 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 15
Letzte 7 Tage: 69
Letzte 30 Tage: 390
Insgesamt: 7,171
