Einleitung
If your Lady Zest Q Nasal CPAP Mask with Headgear is cracked and leaking air use this guide to repair the crack in the mask. The mask is used to to provide a seal around your nose so that positive pressure can maintained when you breathe. Before you begin this guide you will check the mask for where the crack is located and how big it is. Be sure to wear latex gloves that can be disposed of while working with the resin, as it is very sticky and once dried will be harder to remove safely.
Was du brauchst
Trim the edges of the fiberglass sheet into small strips that cover the crack on the mask.
Mix in some of the fiberglass strands into the resin until the strands are fully saturated with resin.
Scoop up some of the resin and fiberglass mixture with the toothpick.
Apply the fiber glass and resin combo onto the crack and, using another toothpick, arrange the fiberglass to cover the crack.
Repeat until the hole has been sufficiently covered.
Check the mask to ensure that the crack is fully sealed.
If there is still pressure loss through the crack, apply more resin to the crack until it is sealed.
