Zum Hauptinhalt wechseln
How to Fix a Delta 5-Function Showerhead Model 75554
Was du brauchst
  1. How to Fix a Delta 5-Function Showerhead Model 75554, How to Fix a Delta 5-Function Showerhead Model 75554: Schritt 1, Bild 1 von 3 How to Fix a Delta 5-Function Showerhead Model 75554, How to Fix a Delta 5-Function Showerhead Model 75554: Schritt 1, Bild 2 von 3 How to Fix a Delta 5-Function Showerhead Model 75554, How to Fix a Delta 5-Function Showerhead Model 75554: Schritt 1, Bild 3 von 3
    • Unscrew the head of the shower from the pipe with a pipe wrench.
    • While using the pipe wrench, make sure not to clamp it too tight because it will crack the plastic.
  2. How to Fix a Delta 5-Function Showerhead Model 75554: Schritt 2, Bild 1 von 2 How to Fix a Delta 5-Function Showerhead Model 75554: Schritt 2, Bild 2 von 2
    • Fill a large bowl with equal parts hot water and white distilled vinegar to get rid of hard water build up.
  3. How to Fix a Delta 5-Function Showerhead Model 75554: Schritt 3, Bild 1 von 2 How to Fix a Delta 5-Function Showerhead Model 75554: Schritt 3, Bild 2 von 2
    • With the tip of a pocketknife, pick out the rubber, black washer in the attachment.
    • Using your fingertips press a new 1" black rubber washer into the head attachment. The new washer will allow water to flow correctly with more pressure.
    • Pocketknives can be very very sharp!
  4. How to Fix a Delta 5-Function Showerhead Model 75554: Schritt 4, Bild 1 von 2 How to Fix a Delta 5-Function Showerhead Model 75554: Schritt 4, Bild 2 von 2
    • Wipe down with shower pipe with a hot water and vinegar soaked scrub brush.
  5. How to Fix a Delta 5-Function Showerhead Model 75554: Schritt 5, Bild 1 von 2 How to Fix a Delta 5-Function Showerhead Model 75554: Schritt 5, Bild 2 von 2
    • Wrap Teflon tape around the legs of the spout about 3 times to ensure that it will screw on tight when the head is put back on.
    • Now is the time to take the shower head out of the vinegar water.
  6. How to Fix a Delta 5-Function Showerhead Model 75554: Schritt 6, Bild 1 von 3 How to Fix a Delta 5-Function Showerhead Model 75554: Schritt 6, Bild 2 von 3 How to Fix a Delta 5-Function Showerhead Model 75554: Schritt 6, Bild 3 von 3
    • Twist the shower head back onto the pipe and tighten it with the pipe wrench.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Faith Henson
160 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 71
Insgesamt: 1,053
