Zum Hauptinhalt wechseln
How to Fix a Dirty Censor in a Corsair Harpoon RGB
Was du brauchst
  1. How to Fix a Dirty Censor in a Corsair Harpoon RGB, How to Fix a Dirty Censor in a Corsair Harpoon RGB: Schritt 1, Bild 1 von 2 How to Fix a Dirty Censor in a Corsair Harpoon RGB, How to Fix a Dirty Censor in a Corsair Harpoon RGB: Schritt 1, Bild 2 von 2
    • Start by flipping the mouse over to view the flat side of the mouse.
    • Remove the mouse feet to reveal the screws holding the bottom and top part of the mouse together.
  2. How to Fix a Dirty Censor in a Corsair Harpoon RGB: Schritt 2, Bild 1 von 3 How to Fix a Dirty Censor in a Corsair Harpoon RGB: Schritt 2, Bild 2 von 3 How to Fix a Dirty Censor in a Corsair Harpoon RGB: Schritt 2, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the screws that hold the mouse together.
    • Once the screws are removed, pull the mouse apart by holding the top and bottom pieces.
    • The mouse will be pulled into two pieces: the top (rounded part) and bottom (flat part).
  3. How to Fix a Dirty Censor in a Corsair Harpoon RGB: Schritt 3, Bild 1 von 1
    • After the mouse has been pulled apart, the flex cable will be visible. This must be removed before continuing.
    • To remove the flex cable, gently pull the cable clip until it becomes unlatched.
  4. How to Fix a Dirty Censor in a Corsair Harpoon RGB: Schritt 4, Bild 1 von 2 How to Fix a Dirty Censor in a Corsair Harpoon RGB: Schritt 4, Bild 2 von 2
    • Remove the motherboard. The motherboard is mounted on the mouse, so gently remove by simply pulling the motherboard from within the mouse.
  5. How to Fix a Dirty Censor in a Corsair Harpoon RGB: Schritt 5, Bild 1 von 2 How to Fix a Dirty Censor in a Corsair Harpoon RGB: Schritt 5, Bild 2 von 2
    • Once the motherboard is removed, the optical sensor will be fully exposed. This is the piece that is causing the lag in the mouse.
    • The optical sensor is dirty, and needs to be gently cleaned with a Q-tip or soft cloth dipped in 90% isopropyl alcohol.
Abschluss
To disassemble, clean, and reassemble your mouse, follow these guidelines.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Muy buena guia. Me fue muy util. Gracias y saludos.
Bolzano - Antwort
why did you opened it if you just cleaned eye with alcohol
antoncoinz - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 40
Letzte 30 Tage: 179
Insgesamt: 6,120
