Zum Hauptinhalt wechseln
How to Fix a Faulty Button on a Mayflash F300
Was du brauchst
  1. How to Fix a Faulty Button on a Mayflash F300, How to Fix a Faulty Button on a Mayflash F300: Schritt 1, Bild 1 von 2 How to Fix a Faulty Button on a Mayflash F300, How to Fix a Faulty Button on a Mayflash F300: Schritt 1, Bild 2 von 2
    • Flip around the Mayflash F300, so that the metal panel is facing you.
    • It may be helpful to place the device on a box if you cannot hold it, as the joystick would otherwise be under pressure.
  2. How to Fix a Faulty Button on a Mayflash F300: Schritt 2, Bild 1 von 3 How to Fix a Faulty Button on a Mayflash F300: Schritt 2, Bild 2 von 3 How to Fix a Faulty Button on a Mayflash F300: Schritt 2, Bild 3 von 3
    • Unscrew the six 9 mm Phillips #00 screws that hold together the metal panel.
    • Gently pry the panel away once it is unscrewed.
  3. How to Fix a Faulty Button on a Mayflash F300: Schritt 3, Bild 1 von 2 How to Fix a Faulty Button on a Mayflash F300: Schritt 3, Bild 2 von 2
    • Unplug the two cables going into the button you wish to clean or replace.
    • These two cables can be quite stubborn to remove, so gently wiggling them as you pull will make it easier.
  4. How to Fix a Faulty Button on a Mayflash F300: Schritt 4, Bild 1 von 1
    • Squeeze the two tabs that are on either side of the button and push it out.
  5. How to Fix a Faulty Button on a Mayflash F300: Schritt 5, Bild 1 von 1
    • Grab your toothbrush and clean out all the dirt you may find inside and around the button.
    • Alternatively, if you wish to install an entirely new button, you can simply set aside the old one.
  6. How to Fix a Faulty Button on a Mayflash F300: Schritt 6, Bild 1 von 2 How to Fix a Faulty Button on a Mayflash F300: Schritt 6, Bild 2 von 2
    • With your button now clean and ready to go, place it in the empty slot and push it back down. Make sure it snaps in place.
  7. How to Fix a Faulty Button on a Mayflash F300: Schritt 7, Bild 1 von 1
    • Reconnect the two cables to the button.
  8. How to Fix a Faulty Button on a Mayflash F300: Schritt 8, Bild 1 von 1
    • Take the back panel of the arcade stick and screw it back in place.
Abschluss
Hopefully these steps were clear and useful to you! Happy gaming!
Ali Fareed
157 Reputation
1 Anleitung geschrieben
York University, Team P-99, O'Regan Winter 2024 Mitglied von York University, Team P-99, O'Regan Winter 2024
YORK-O'REGAN-W24SPG99
1 Mitglied
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 73
Insgesamt: 895
