Zum Hauptinhalt wechseln
How to Fix a Feather Cat Toy
Was du brauchst
  1. How to Fix a Feather Cat Toy, How to Fix a Feather Cat Toy: Schritt 1, Bild 1 von 2 How to Fix a Feather Cat Toy, How to Fix a Feather Cat Toy: Schritt 1, Bild 2 von 2
    • Slide a crimp onto the cat toy's line.
    • Thread the line through the ring of the key clasp.
    • You should have a small loop formed at the end of the line.
  2. How to Fix a Feather Cat Toy: Schritt 2, Bild 1 von 2 How to Fix a Feather Cat Toy: Schritt 2, Bild 2 von 2
    • Slide the crimp down to close the loop. Make sure that the crimp covers each part of the line.
    • Use your crimping tool or pliers in order to secure the crimp.
  3. How to Fix a Feather Cat Toy: Schritt 3, Bild 1 von 1
    • Apply super glue to any cracks visible on the feather capsule for maximum security.
    • Let the feather capsule piece dry entirely before proceeding to the next step.
  4. How to Fix a Feather Cat Toy: Schritt 4, Bild 1 von 1
    • Use regular glue to fill the inner portion of the feather capsule.
    • Fill it up only halfway in order to leave enough space for feathers.
  5. How to Fix a Feather Cat Toy: Schritt 5, Bild 1 von 2 How to Fix a Feather Cat Toy: Schritt 5, Bild 2 von 2
    • Individually insert the quill of each feather into the capsule.
    • Work quickly so that the glue doesn’t dry and cause the feathers to stick in the wrong direction.
  6. How to Fix a Feather Cat Toy: Schritt 6, Bild 1 von 1
    • Press down on the clasp lever to open up the hinge.
    • Slide the loop on the feather connector into the clasp to reconnect the toy.
Abschluss
Repeat the instructions in this guide every time your cat breaks their toy!
Eine weitere Person hat diese Anleitung absolviert.
Isabella Markell
148 Reputation
1 Anleitung geschrieben
UC Davis, Team 1-6, Whithaus Spring 2024 Mitglied von UC Davis, Team 1-6, Whithaus Spring 2024
UCD-WHITHAUS-S24S1G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 50
