Einleitung
This guide will outline how to fix a feather cat toy that your cat has destroyed. This can happen when your cat gets too aggressive with the feathers on the end of the string, leaving the toy unusable.
Using tools you will most likely already own, repairing the toy yourself will be cheaper than buying a new one.
Was du brauchst
Slide a crimp onto the cat toy's line.
Thread the line through the ring of the key clasp.
Slide the crimp down to close the loop. Make sure that the crimp covers each part of the line.
Use your crimping tool or pliers in order to secure the crimp.
Apply super glue to any cracks visible on the feather capsule for maximum security.
Press down on the clasp lever to open up the hinge.
Slide the loop on the feather connector into the clasp to reconnect the toy.
Repeat the instructions in this guide every time your cat breaks their toy!
Eine weitere Person hat diese Anleitung absolviert.
