Einleitung
Have you ever opened a door too hard and it hit the wall causing a small hole in the wall? This is a problem that so many people have, especially with children in the home. Most modern homes have walls made of a material called drywall. A hole in drywall is very easy to patch. It requires no prior skill or experience. This fix requires inexpensive tools and materials that you may find at a local hardware store or you may even already have some of these items at home. This is a guide on how to patch a small hole in the wall for beginners. This guide will include a complete step by step guide along with all tools and materials that are needed to complete this task.
Was du brauchst
Use a damp sponge to apply moisture to make the mesh stick to the wall, covering the entire hole.
Use a drywall knife to apply the drywall compound over the mesh. Make sure to spread a generous amount over the entire mesh.
Let the compound dry for about 30 minutes.
Once compound is dry, use sandpaper to smooth out the entire surface of the dried compound.
4 weitere Personen haben diese Anleitung absolviert.
