Zum Hauptinhalt wechseln
Einleitung
In this guide you will be learning how to fix a hole that was formed on a chicken wire fencing panel. The part that we are replacing is the missing piece of wire. We will be placing a bigger piece over the hole to cover and fix the missing piece. When performing this fast fix you will need gloves and safely goggles for protection when it comes to protecting your hands and eyes.
  1. Measure the area that is missing the chicken wire. Measure the area that is missing the chicken wire.
    • Measure the area that is missing the chicken wire.
  2. Measure a piece of chicken wire to place on top.
    • Measure a piece of chicken wire to place on top.
    • Make sure you make it bigger than the hole, so you can have excess to tie to the remaining fence. An extra inch of wire on each side should be sufficient.
  3. Place the replacement piece on top of the hole.
    • Place the replacement piece on top of the hole.
    • Put it vertical so that the long side is reaching the fence board (if you are close to a fence post).
  4. Staple the chicken wire down to the fence board for extra strength. Staples should be hammered all the way into the fence board.
    • Staple the chicken wire down to the fence board for extra strength.
    • Staples should be hammered all the way into the fence board.
    • Repeat this all along the edge of the patch that lines up with the fence board.
  5. Twist the chicken wire, bending and molding it into the pre-existing fencing. This step is where the gloves and plyers become useful, when protecting your skin from the sharp wire. This step is where the gloves and plyers become useful, when protecting your skin from the sharp wire.
    • Twist the chicken wire, bending and molding it into the pre-existing fencing.
    • This step is where the gloves and plyers become useful, when protecting your skin from the sharp wire.
  6. This is the end result of twisting the two pieces together to form one whole piece.
    • This is the end result of twisting the two pieces together to form one whole piece.
Ziellinie
Ein weiterer Nutzer hat diese Anleitung absolviert.
UW Tacoma, Team S1-G14, Cardinal Spring 2020 Mitglied von UW Tacoma, Team S1-G14, Cardinal Spring 2020
UWT-CARDINAL-S20S1G14
1 Mitglied
1 Anleitung geschrieben
Ein Kommentar
If you ***need a fence company***, our company can help you out with this best fencing in town. We have listed some of the important areas which urgently need fencing.
clear the lot - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 13
Letzten 30 Tage: 47
Insgesamt: 905
