Zum Hauptinhalt wechseln
How to Fix a Hole in a Pant Pocket
Was du brauchst
  1. How to Fix a Hole in a Pant Pocket, How to Fix a Hole in a Pant Pocket: Schritt 1, Bild 1 von 2 How to Fix a Hole in a Pant Pocket, How to Fix a Hole in a Pant Pocket: Schritt 1, Bild 2 von 2
    • Flip the pocket inside out.
  2. How to Fix a Hole in a Pant Pocket: Schritt 2, Bild 1 von 2 How to Fix a Hole in a Pant Pocket: Schritt 2, Bild 2 von 2
    • Carefully align the ripped part of the pocket together.
  3. How to Fix a Hole in a Pant Pocket: Schritt 3, Bild 1 von 3 How to Fix a Hole in a Pant Pocket: Schritt 3, Bild 2 von 3 How to Fix a Hole in a Pant Pocket: Schritt 3, Bild 3 von 3
    • Put a sewing pin into a stable piece of fabric to make a hole.
    • Carefully remove the pins.
  4. How to Fix a Hole in a Pant Pocket: Schritt 5, Bild 1 von 3 How to Fix a Hole in a Pant Pocket: Schritt 5, Bild 2 von 3 How to Fix a Hole in a Pant Pocket: Schritt 5, Bild 3 von 3
    • Carefully insert the a threaded sewing needle into the hole you created at one end of the tear.
    • Sew along the length of the tear, joining the two pieces of fabric together.
    • Be very careful when using needle as the point can be very sharp and lead to injury.
  5. How to Fix a Hole in a Pant Pocket: Schritt 6, Bild 1 von 2 How to Fix a Hole in a Pant Pocket: Schritt 6, Bild 2 von 2
    • Sew around the ending part a couple times to prevent it from loosen again.
  6. How to Fix a Hole in a Pant Pocket: Schritt 7, Bild 1 von 1
    • Tie a few knots on both ends of the closed tear to ensure the stitching doesn't come loose.
    • Carefully cut the remaining thread.
    • Be very careful while cutting the thread to avoid cutting some part of the material also.
Abschluss
Dolapo Ajose
220 Reputation
1 Anleitung geschrieben
York University, Team F-7, Woodhouse Fall 2021 Mitglied von York University, Team F-7, Woodhouse Fall 2021
YORK-WOODHOUSE-F21SFG7
1 Mitglied
Ein Kommentar
I found a good reference video for this guide: https://youtube.com/watch?v=LJ5y4mLVbY0
5moufl - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 31
Letzte 30 Tage: 104
Insgesamt: 3,903
