Zum Hauptinhalt wechseln
How to Fix a Hole in a Pant Pocket
Was du brauchst
    1. How to Fix a Hole in a Pant Pocket, How to Fix a Hole in a Pant Pocket: Schritt 1, Bild 1 von 2 How to Fix a Hole in a Pant Pocket, How to Fix a Hole in a Pant Pocket: Schritt 1, Bild 2 von 2
      • Flip the pocket inside out.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Fix a Hole in a Pant Pocket: Schritt 2, Bild 1 von 2 How to Fix a Hole in a Pant Pocket: Schritt 2, Bild 2 von 2
      • Carefully align the ripped part of the pocket together.
      Frag FixBot
    3. How to Fix a Hole in a Pant Pocket: Schritt 3, Bild 1 von 3 How to Fix a Hole in a Pant Pocket: Schritt 3, Bild 2 von 3 How to Fix a Hole in a Pant Pocket: Schritt 3, Bild 3 von 3
      • Put a sewing pin into a stable piece of fabric to make a hole.
      Frag FixBot
      • Carefully remove the pins.
      Frag FixBot
    4. How to Fix a Hole in a Pant Pocket: Schritt 5, Bild 1 von 3 How to Fix a Hole in a Pant Pocket: Schritt 5, Bild 2 von 3 How to Fix a Hole in a Pant Pocket: Schritt 5, Bild 3 von 3
      • Carefully insert the a threaded sewing needle into the hole you created at one end of the tear.
      • Sew along the length of the tear, joining the two pieces of fabric together.
      • Be very careful when using needle as the point can be very sharp and lead to injury.
      Frag FixBot
    5. How to Fix a Hole in a Pant Pocket: Schritt 6, Bild 1 von 2 How to Fix a Hole in a Pant Pocket: Schritt 6, Bild 2 von 2
      • Sew around the ending part a couple times to prevent it from loosen again.
      Frag FixBot
    6. How to Fix a Hole in a Pant Pocket: Schritt 7, Bild 1 von 1
      • Tie a few knots on both ends of the closed tear to ensure the stitching doesn't come loose.
      • Carefully cut the remaining thread.
      • Be very careful while cutting the thread to avoid cutting some part of the material also.
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
York University, Team F-7, Woodhouse Fall 2021 Mitglied von York University, Team F-7, Woodhouse Fall 2021
YORK-WOODHOUSE-F21SFG7
1 Mitglied
12 Anleitungen geschrieben
1 Kommentar zur Anleitung
I found a good reference video for this guide: https://youtube.com/watch?v=LJ5y4mLVbY0
5moufl - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 22
Letzte 30 Tage: 78
Insgesamt: 5,981
