Einleitung
If your Honda GCV160 lawnmower doesn't start despite having a full tank, you may have gotten water caught in its fuel line. This guide will teach you how to remove the water from anywhere it may get caught and get the lawnmower working again.
Note: Make sure to place the rag beneath the part of the lawnmower you are working on so any leaking fuel lands on the rag rather than on the lawnmower or the ground.
Was du brauchst
Move the dial to a vertical position to close the fuel line.
Use the screwdriver to push the right tension pin to the right so the hose can be removed.
Remove the right hose by wiggling the screwdriver between the hose and the tube where it is attached.
Move the tension pin to the left to allow the hose to be removed.
Remove the left hose and catch the fluids that leak out.
Remove the 10 mm bolt holding the carburetor fuel cup in place.
Remove the carburetor fuel cup
Use the rag to clean the inside of the carburetor fuel cup after it has been removed.
Place the detached hoses back to the fuel line.
Move the pins back to the end of the hose to hold them in place.
Use the fuel can to refill the lawnmower now that the contaminated fuel has been removed.
With the water out of the fuel line, the lawnmower should be ready for use.
2 weitere Personen haben diese Anleitung absolviert.
