Zum Hauptinhalt wechseln
How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line
Was du brauchst
  1. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line, How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: Schritt 1, Bild 1 von 1
    • Move the dial to a vertical position to close the fuel line.
    • This will prevent fluids from continuing to move freely throughout the lawnmower.
  2. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: Schritt 2, Bild 1 von 3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: Schritt 2, Bild 2 von 3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: Schritt 2, Bild 3 von 3
    • Use the screwdriver to push the right tension pin to the right so the hose can be removed.
    • Remove the right hose by wiggling the screwdriver between the hose and the tube where it is attached.
    • Have the empty bottle ready to use as soon as the hose is detached from the fuel line.
  3. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: Schritt 3, Bild 1 von 1
    • Place the hose into a bottle to catch the leaking fluid from the fuel tank.
    • More liquid will be released from the right hose than in any other part of the process.
  4. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: Schritt 4, Bild 1 von 3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: Schritt 4, Bild 2 von 3 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: Schritt 4, Bild 3 von 3
    • Move the tension pin to the left to allow the hose to be removed.
    • Remove the left hose and catch the fluids that leak out.
  5. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: Schritt 5, Bild 1 von 2 How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: Schritt 5, Bild 2 von 2
    • Remove the 10 mm bolt holding the carburetor fuel cup in place.
    • Remove the carburetor fuel cup
    • Use the rag to clean the inside of the carburetor fuel cup after it has been removed.
    • Let any fluid released from removing the carburetor spill onto the rag.
  6. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: Schritt 6, Bild 1 von 1
    • Tilt the lawnmower forward so any remaining fluids can make their way out.
  7. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: Schritt 7, Bild 1 von 1
    • Place the detached hoses back to the fuel line.
    • Move the pins back to the end of the hose to hold them in place.
  8. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: Schritt 8, Bild 1 von 1
    • Use the fuel can to refill the lawnmower now that the contaminated fuel has been removed.
  9. How to Fix a Honda GCV160 Lawnmower With Water in the Fuel Line: Schritt 9, Bild 1 von 1
    • Turn the dial to a horizontal position to reopen the fuel line.
Abschluss
With the water out of the fuel line, the lawnmower should be ready for use.
2 weitere Personen haben diese Anleitung absolviert.
CSU Los Angeles, Team 6-10, Briggs Spring 2022 Mitglied von CSU Los Angeles, Team 6-10, Briggs Spring 2022
CSULA-BRIGGS-S22S6G10
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 20
Letzte 30 Tage: 102
Insgesamt: 1,813
