Zum Hauptinhalt wechseln
How to Fix a Leaning Wooden Gate
Was du brauchst
  1. How to Fix a Leaning Wooden Gate, How to Fix a Leaning Wooden Gate: Schritt 1, Bild 1 von 2 How to Fix a Leaning Wooden Gate, How to Fix a Leaning Wooden Gate: Schritt 1, Bild 2 von 2
    • Begin by measuring the gap under the gate to determine the exact height needed for correction.
  2. How to Fix a Leaning Wooden Gate: Schritt 2, Bild 1 von 1
    • Choose any object that is the same size as the measured gap.
    • Place the selected object under the gate to ensure the gate is level and straight.
  3. How to Fix a Leaning Wooden Gate: Schritt 3, Bild 1 von 3 How to Fix a Leaning Wooden Gate: Schritt 3, Bild 2 von 3 How to Fix a Leaning Wooden Gate: Schritt 3, Bild 3 von 3
    • Place the wheel on the side where the door is leaning down.
    • Mark the hole location for drilling.
    • Use masking tape only if the door is the same colour as your marking object.
  4. How to Fix a Leaning Wooden Gate: Schritt 4, Bild 1 von 3 How to Fix a Leaning Wooden Gate: Schritt 4, Bild 2 von 3 How to Fix a Leaning Wooden Gate: Schritt 4, Bild 3 von 3
    • Drill holes on the marked circles.
    • Ensure your holes are the same size as the screw you are using.
  5. How to Fix a Leaning Wooden Gate: Schritt 5, Bild 1 von 2 How to Fix a Leaning Wooden Gate: Schritt 5, Bild 2 von 2
    • Attach the wheel and place the screws .
    • Depending on what the kit provides, use a wrench to tighten the bolts or a screwdriver to tighten the screws.
    • Ensure that the screw is tightened securely to prevent a loose wheel.
  6. How to Fix a Leaning Wooden Gate: Schritt 6, Bild 1 von 2 How to Fix a Leaning Wooden Gate: Schritt 6, Bild 2 von 2
    • Remove the object you placed underneath.
Abschluss
Test out your newly added wheels, if it is wobbly make sure to tighten the wheels again.
TenzinY
133 Reputation
1 Anleitung geschrieben
York University, Team 2-26, O'Regan Fall 2023 Mitglied von York University, Team 2-26, O'Regan Fall 2023
YORK-O'REGAN-F23S2G26
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 25
Insgesamt: 136
