Einleitung
Use this guide to fix your leaning wooden gate. Wooden gates start to lean downwards over time as the latch cannot withstand the weight of the door. Fix your leaning wooden gate by installing a Spring Loaded wheel. Installing the wheel provides a permanent fix, ensuring the door stands straight and well balanced.
Was du brauchst
Begin by measuring the gap under the gate to determine the exact height needed for correction.
Choose any object that is the same size as the measured gap.
Place the selected object under the gate to ensure the gate is level and straight.
Place the wheel on the side where the door is leaning down.
Mark the hole location for drilling.
Drill holes on the marked circles.
Ensure your holes are the same size as the screw you are using.
Attach the wheel and place the screws .
Depending on what the kit provides, use a wrench to tighten the bolts or a screwdriver to tighten the screws.
Ensure that the screw is tightened securely to prevent a loose wheel.
Test out your newly added wheels, if it is wobbly make sure to tighten the wheels again.
