Zum Hauptinhalt wechseln
How to Fix a Loose Connector in an Anivia 1080p Webcam
Was du brauchst
  1. How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 1, Bild 1 von 3 How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 1, Bild 2 von 3 How to Fix a Loose Connector in an Anivia 1080p Webcam, How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 1, Bild 3 von 3
    • Pry open the face plate of the webcam using the iFixit opening pick or another safe tool, and set it aside.
  2. How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 2, Bild 1 von 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 2, Bild 2 von 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 2, Bild 3 von 3
    • Remove the three main screws using a Phillips screwdriver while carefully holding the camera motherboard in place.
  3. How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 3, Bild 1 von 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 3, Bild 2 von 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 3, Bild 3 von 3
    • Remove the camera and motherboard from the casing carefully.
  4. How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 4, Bild 1 von 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 4, Bild 2 von 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 4, Bild 3 von 3
    • Detach the cable from the connecter on the motherboard.
    • Pull from the plastic as to not damage any of the wires.
  5. How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 5, Bild 1 von 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 5, Bild 2 von 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 5, Bild 3 von 3
    • Identify where the connector is loose and solder the piece back into place.
    • Use only as little solder as needed to keep functionality in tact.
    • Caution: The soldering iron is hot and should be handled with care.
  6. How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 6, Bild 1 von 2 How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 6, Bild 2 von 2
    • Reattach the cable to the connector.
  7. How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 7, Bild 1 von 2 How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 7, Bild 2 von 2
    • Place the motherboard and camera back into the casing.
  8. How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 8, Bild 1 von 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 8, Bild 2 von 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 8, Bild 3 von 3
    • Screw the camera and motherboard back into place.
  9. How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 9, Bild 1 von 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 9, Bild 2 von 3 How to Fix a Loose Connector in an Anivia 1080p Webcam: Schritt 9, Bild 3 von 3
    • Snap the faceplate covering back into place.
Ziellinie
Duncan Holloway
169 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 53
Insgesamt: 880
